safe menu scène recel
If the SQ if a huge step step forward in the sound quality compare to the GLD, the safe menu on the scenes is something else. It looks to me that EQs, Compressors, faders should have the option to be made recale safe. Once you start a show and you make an ajustement, you don’t want to end up redoing this adjustment every scene recalled.
Hi Oli,
You can achieve this by using the global filters to ‘block’ changes to the Input Processing and Input Faders/Pan.
Alex
Hi Alex, yes, I get it but it will also block the mix send. Correct me if I am wrong. Fiddling about, i haven’t been able to sélect the parametres without blocking the whole input process and then losing the sends requiered for the particular scene. Thanks for your help.
unless… in the global filtre, input processing, is it the one? Is it the way to block recalls of EQ, Comp and Gate?
Hi Alex,
Maybe can you add in the manual more informations about block/recall and safe fonctions like the “reset fonction” page (17 V1.2.0)
(But I don’t know your manual update for nearly 1.3 version?).
Best
Hi Oli,
Yep, that’s the one!
Flo84, we’ll look into that one.
Alex
