Hello community
I own a SQ6 in software version 1.5.2.
So far I have 4 effect slots controlled via the 4 FX send busses.
I have configured 10 scenes for my band with different effect combinations on the 4 FX buses and switch to the appropriate scene in live operation depending on the song.
For the Global Filters, I only have the FX parameters set to allow, everything else is blocked.
If changes need to be made to EQ, Gate, or Compressors during a gig, then those changes will affect all scenes.
So channel settings of EQ - gate, compressor and fader are not switched when changing scenes. That’s exactly how I want it.
Last week, I installed the Dynamic Trio Pack.
The two main vocals and the bass each got a Dyn EQ in the insert (in FX slot 5, 6 and 7). Effect slot 8 I used the multiband compressor as an insert on the master bus.
I have saved the assignment of effect slots 5-8 on each of my 10 scenes.
If I make changes in live operation with the current settings, e.g. to one of the DynEQ or to the Mutiband compressor on the master bus, then the changes are gone at the next scene change.
However, I want the changes to the 3 DynEQ and the multiband compressor to be unaffected by a scene change.
How can I achieve this?
I have already tried to protect the FX slots 5-8 via the saves from a change of the parameters during a scene change, but unfortunately this did not work.
Kind Regards from Germany
