Save, Copy, Paste, Reset for Pan
Hi guys,
I´d like the pan settings to be storeable in the input channel library. And it would be cool to include the pan setting into the copy - paste - reset functionality. Maybe changeable in the surface preferances, if there are any major downsides I do not see at the moment.
Cheers,
André
Hi Andre,
I think the pan should be part of the routing, but I’m afraid the routing is not available for copy-paste-reset
at least I didn’t find it in Mixpad…
I have no console at hand, can you try it please on the hardware?
Cheers Steffen
I’m not sure about channel library or copy/paste but it is definitely available for reset.
With a channel selected hold down Reset and then move the Pan rotary (you may have to move it some way). It then toggles between hard left, dead centre and hard right depending on the direction of turn of the rotary - very useful!
With a channel selected hold down Reset and then move the Pan rotary (you may have to move it some way). It then toggles between hard left, dead centre and hard right depending on the direction of turn of the rotary – very useful!
Yeah, I know, it´s a cool trick. Same with the faders. But I would like to see a full channel reset (including pan, maybe even routing?), when I reset a channel.
@steffenR
I just checked it on my SQ: the routing of a channel is not copy-paste-resetable with the dedicated buttons.
Thanks Andre for checking it… so it works the same on Mixpad
