Hi everyone,
I am new to the digital mixers of A&H and currently working with an SQ6.
I’ve got it set up in our church, where we have three different music bands. For each band i have created scenes for the Sunday service and for when they are practicing during the week. For the Main Mix it works fine, but the monitor setting are not saved and need to be adjusted manually every time. E.g. band A was the last band that played and now it’s band’s B turn, I recall their scene but still end up with the monitor settings of band A. Can somebody explain to me how I get the monitor setting also stored into the scenes?
Interesting…
I will check this Saturday in my desk and let you know…
heinrich, you are correct that by default the mixes should also be recalled with a scene change.
Have you checked to see if any safes or scene filters have been applied to the scenes you are using? Either of these could prevent the mixer from recalling the settings you are looking for.
If you find that a safe or filter has been set, you should find that the settings from your last stored scene should be recalled with each scene once these are removed.
Hope that helps!
I’ve checked it and you are right, the safes have been applied to the monitor channels. Deactivating the safes solved the issue.
Thank you very much for your help!
