i would like to know how to save complete channel strip settings in the qu-16. I have set up different acoustic guitars and vocalists but can’t figure out how to save the whole channel strip including peq preamp comp and fx etc. I have the channel selected processing button pushed channel strip selected in the touch screen but when i hit Fn button i don’t see anyplace to store the strip… was looking for the overview tab where i thought store and recall would be but can’t find it. thanx
If I’m understanding your request. Setup your channel. Push the function button that says Library. On that screen press USER. On the right side it says channel. Click store new. Then I would click the overwrite again. Select next channel and do the same. You will have to recall them as needed. Hope that helps.
Other approach is to save all the board’s settings as a Scene and recall that-- depends what you want to do really. A scene can’t be saved per channel- it is the whole board’s current settings.
Yes, that’s another approach, but the first suggestion made about using individually recallable presets in the User library is the proper way. Using scenes in this context is not really appropriate even though possible.
