Hi, can someone walk me through the steps of saving a scene to a USB as a backup on the dLive C3500? Or is there a better way to go about this, as in backing up the entire system.
save a show under “Utility” (store show or overwrite), insert USB key of choice and hi-light the show you want to save and select “copy to usb” then you’re done.This will back up the whole system
hope that helps
Ray
The show contains your scenes, these you can import to the current show
