Hi all
Just updated to latest firmware and since I did I can store a show on the GLD but when I try and copy to USB I keep getting an error message, any ideas? Thanks
Hi all
updated as well to newest firmware, store and copy to usb was no problem! Check your USB-Drive! Maybe not enough space? And if you are using the second usb-connection at the same time it can be a problem! If nothing helps, try another USB-drive!
GLD-80 / AR2412 / AR84 / Qu-16
Thanks for the reply I have a show tonight and will try out a different USB drive,on another note when I tried to record onto the current drive that I’m using it would only record on the lower of the two USB ports were as before I always used the top one,would charging my ipad in the spare USB port be causing a problem?
quote:
Originally posted by gar01Thanks for the reply I have a show tonight and will try out a different USB drive,on another note when I tried to record onto the current drive that I’m using it would only record on the lower of the two USB ports were as before I always used the top one,would charging my ipad in the spare USB port be causing a problem?
iPAD will not charge… iPhone does…
lack of power in the usb?
my ipad say’s connected but “not loading”…
GulikerAV.nl
GLD80
AR24/12
AR8/4 (*2)
And now also the QU-16
I’m so happy with them
