When I change to a new blank scene my QU starts from the last scene. I would like it to be blank. Is this a common thing or is there something I’m missing in the manual.
Thing is, your “blank” will probably not be the same as mine. If fact I have several “blanks” or starting points, depending on what sort or show it is, if I’m using a stage box, radio mic setup, etc. I’ve just made another “blank” for QLab to playback on multiple tracks for theatre shows.
Save your version of “blank” and start from that.
Just select a blank. Store then hold down Reset Mix Settings. Now you have a blank slate.
Thank you…
