About global filtering: I have certain parameters blocked. Now if I tweak, say, blocked EQ/comp- settings on a certain scene, and store the scene anew, do my changes apply to all subsequent scenes? Do I have to unblock the parameters before storing the new settings (and then block them again) ?
Why not just answer a simple question- the manual is unclear on the subject. And I have a premiere coming up in a couple of days… still struggling with the counter-intuitive scene-system. Have had sudden gain jumps etc.
And please, try to implement an auto-incremental “scene previous”- softkey-command. Getting back now is just too slow.
Really? Well I´m still trying to get to grips with the filter-logic… I want to have a different eq on one input for my last scene. I make the changes and store- the new curve finds its way to all scenes. I have ch/st blocked. The screen states that a filter affects all scenes (that´s why it´s “global”, I guess), but on the other hand “you can have different filters for each scene”. This is where I get confused- what do I need to block or allow to have a change affect only one scene?
Seems like a contradiction here- I would have thought disabling the block from the scene before the last would allow a different setting to affect only the last scene… what I do not understand, that while the manual says you can have different filters for each scene, unblocking a parameter from one scene unblocks it globally. What is this “per scene”- filtering, then?
…or so I thought. The whole thing is getting too weird for me. I have a certain setting for walk-in music for my first scene, the from there on the eq is flat for that channel. It stays that way until I reach the last scene, then when I return to the beginning, the first scene mysteriously has changed the eq-curve to that of the last scene. Everything is fine for all other scenes. No matter which combination of blocking I apply, I cannot move from last scene to the first without the console ignoring the original eq.
If I were to design a scene-memory system for a console, it certainly wouldn´t be like this- there is way too much room for errors, too many parameters bundled under “CH/ST”, for instance. You can´t trust your decisions when the board works against you.
The parameters in question are your PEQ settings for a particular channel.
scene 1: a certain PEQ setting for walk-in music
scene 2…N: a flat PEQ setting
where exactly are you putting the scene filters, in scene 1? it sounds like you don’t actually need filters at all.
bear in mind when you “block” an element of a scene, you leave in place whatever’s in the current desk state. it sounds like you have a scene filter on scene 1, blocking the recall of your certain PEQ setting for walk-in music.
I feel I’ve made every possible mistake as far as scene-settings go, and started to be afraid of the CH/ST- button, not knowing if I dare to allow the parameters to change or not…
I have a couple of input channels where there are eq/comp- setting alterations during the course of the show, the aforementioned walk-in being one of them. Now, if I tweak a setting on a scene and store it, are you saying that if nothing is blocked, all other scenes are unaffected? So maybe I could just block preamp-gains globally, since they are about the only settings that stay the same trough the show, and just forget about blocking other parameters? Now that would relieve my anxiety a lot… but I am still afraid of recalling some past eq-settings that are not valid anymore. That’s why I blocked the eq in the first place- when I finally settled on a curve with that horrendous oud-lute, I did not want any changes to happen no matter what else might be going on.
Just to clarify: the “walk-in” channel also plays all my special effects, that’s why there are different settings per scene. Some stuff that was sent to me required drastic eq-corrections. Made in bedroom, you know…
Can you quantify “couple”?
Not sure if I’d go with such a setup live. If you only need few changes between songs, why not use the channel libraries?
Scenes are great to run events with several bands using totally different setups, mics, singers etc. For tweaking only few effects this sounds like a big overkill to me and I’d also fight with scene and global filters for things which should not change (like drum EQ, monitoring, room EQ etc.).
I am with Andreas on this one. It’s amazing to me how new to dig people try to overkill everything. Just stick to basics. How would you have done it on an analog board? That will still probably work best for you now.
Qu’s scene-functionality would be just fine for a music festival, but I’m running a complex theatrical show here, 47 audio cues for a two-hour show. And I want to keep every single unused mic muted, the band stage is tiny, and I have a lot of condensers in there. Trust me, I am a 100% K.I.S.S. -type of guy, but there is a lot happening, the three guys in the band are all multi-instrumentalists, the double-bass player “doubles” on six other stringed instruments during the show. The allocated audio budget dictated the console-choice. But: the Qu is the best-sounding console for the price, IMHO. I don’t think I’m trying to overkill anything, quite the contrary- trying to manage… and eke out a living. And I DON’T HAVE TIME TO RECALL ANY LIBRARY-SETTINGS, things need to change in a 16th- note. Still waiting for the auto-incremental previous scene softkey-command…
Running my own band with the 16 is a total picnic- Love It! But the present show is a different beast, to say the least… but do have great archive recordings! (I now remember that USB-source select lurks behind that CH/ST ?)
I only rarely need to do what you are doing, but a question - do you have soundcheck time to do this kind of presets? Or, if you know what you want, do the changes before a show, in rehearsal time, or at midnight if you have to, or something?
If it helps you feel better, I did a musical show in our music venue with over 40 scene changes, similarly with musicians changing instrumnts and singers changing mic positions, EQ, levels, etc. It took a few days to get the scenes set up. THeN at the last minute, they decided to record the show - and on the Soundcraft Vi4, all 24 channels had to have the direct outs assigned in every one of the 40 scenes individually. Three engineers racing through the scenes and we only missed a couple of direct outs the first day… If we had set the directs before making the different scenes, they all would have been on direct. Or if we’d had a Qu!
(Now I keep directs assigned in the template I start with, even if not needed at the start!)
It takes a lot of prep time for this kind of thing! What you want to do seems simple, really, just takes careful planning.
@GC- there is absolutely no friggin’ way to do this show on an analog desk. And I am not a neophyte, as for digiconsoles. The scene-thing on the Qu just keeps outsmarting me.
@Lou: had three weeks of rehearsals, but I only had chance to listen & take notes, had to get the show up&running in two days. Been trying to “fluentizise” ever since… with this one, even a custom layer-setup will not help- can’t fit all I need on a single layer. Amazing, actually, considering that I’m dealing with a trio. 10 more shows to go, out 73 total. I’ll survive, and I’ve learned a lot about what not to try… thank you guys for your patience!
P.S. Running the show single-handedly- so forgive me the occasional exhaustion?
