I work with a SQ5 in a theatre with musical productions and normal plays. When I setup a show I use many scenes during the musical for differnt kinds of songs or nonmusical parts. I strongly recommend a sort function in the scene manager where you can move scenes or copy and insert scenes in a specific place and and order. I’ve been working with a Yamaha 01V the last ten years and used this function quiet often. I was surprised, and a little bit shocked, that the SQ5 doesn’t feature such a basci function.
Adding this in the Scene Manager would make it way more comfortable to set up new shows.
Being able to easily rearrange scenes would be a welcome feature. In a show with a high scene count changing on a daily basis can be a chore using copy and paste. Buttons to move scenes up or down or being able to drag a scene to a new position would massively speed up workflow.
An easy workaround would be to use an iPad to recall specific scenes by MIDI Location. This way you never have to change the order of the Scene’s. I Use OnSong for Lyrics and other info, however it will also automatically recall Scene’s based on the song I select.
Yes understand regarding scene change using midi. I used set list maker on a console in the past, but it’s another piece of hardware and another app that an extra button in a future firmware update could do.
I second any requests for improvements to the scene management in the SQ. Also, one button press for next scene (and not way the current auto-increment works, which can be confusing), previous scene (there is no auto-decrement) and undo. An offline editor would be a FANTASTIC option and would remove many of the gripes about the SQ series since in most other areas it is brilliant!
Better housekeeping would be a very nice improvement.
Reminds me of when IBM gave a briefing on the new System 7 computer
and everybody started asking about the linkage editor which totally confused the presenter.
Turns out the S/7 folks expected you to hand assemble your programs.
While the audience already had used the larger computers that had a program that assembled your code for you,
which saved a tonne of time and effort. And saved a lot of mistakes and then rework effort, too.
+1 for scene management updates. Being able to move scenes around would make us theater folks a lot happier. I know it can’t be as good as a dLive, so I’m not suggesting an entirely different cue list, but just a simple drag and drop (or using the multi-function encoder) to move them around will be greatly appreciated.
