I miss a function where I can toggle between two (or 3 ) scenes. Usually I’m fine with 2 scence.
One scene has a short reverb, the other scene has a longer reverb.
I would be great if I can toogle with one switch between those two scenes.
I need the other switch for FX on/off (for speech between two songs).
It would be great if I can set a kind of “starting” scene and and “end” scene.
Up to now, the only way to perform such action is to use a midi foot controller and a PC (or BomeBox).
Be aware also that fader are not saved in scene.
Should you change them during the show they won’t be recalled when you change scene.
Yes, that’s what I tried to explain in a wrong manner.
I meant faders position is only saved when you manually save/overwrite that scene but not constantly and automatically.
Thanks for clarifying.
An other option is to use Stage Traxx 3 and send midi command automatically during the song.
The integration btw an Ipad, ST3 and the CQ, (with an USB-C or lightning to USB-B cable) shows absolutely no issue.
And no more pedal or button to press.
