Hello dear A&H team and community,
I would like to propose a feature that I think could significantly extend the value of the CQ series for solo musicians, home recording enthusiasts, and worship teams with limited setup resources: a standalone overdub recording mode using the SD card.
The core idea
The CQ already records multitrack audio to SD via LiveTrax. What I am proposing goes one step further: allowing the CQ to simultaneously record new channels while playing back previously recorded tracks from the same SD session — all without requiring a computer or external DAW.
In practice, the workflow would look like this:
- Record drums and bass on channels 1–4 → saved to SD
- On the next pass, play back those tracks through the mixer while recording guitars on channels 5–6 → all tracks accumulate in the same session
- Continue layering: keys, then vocals, then whatever is needed
Each pass benefits from the CQ’s built-in processing: EQ, compression, effects (reverb, delay, etc.) applied in real time during both recording and playback.
Why this matters
This is essentially a simplified multitrack looper — not for live looping, but for structured song building. It addresses a real need for:
- Solo musicians who cannot record all instruments simultaneously
- Small worship teams or rehearsal environments doing demo/mockup recordings
- Educators and students building arrangements layer by layer
- Anyone who wants a minimal setup without a laptop, audio interface, or DAW
The key value proposition is that the CQ already has everything needed: multitrack I/O, SD recording, built-in effects, and a clean preamp stage. This feature would not require new hardware — only a firmware update that enables simultaneous SD playback and record within the same session.
Scope and limitations (realistic expectations)
I am not proposing that the CQ replace a full DAW. The feature would intentionally be simple:
- No non-destructive editing, no clip-based timeline
- No tempo grid or MIDI sequencing
- Processing limited to what the CQ already offers internally
- Sync based on a fixed session start point
Think of it as a standalone sketch pad — good enough for demos and arrangements, without the overhead of setting up a full recording environment.
I would be very interested to know whether this is technically feasible given the current SD and DSP architecture of the CQ, and whether there is interest from other users in this direction.
Best regards
