Second Screen on SQ serie
It woud be nice if we can connect a second screen on the SQ serie without the need to have the ipad with wifi
Laptop on network port.
There is no possibility for a second screen directly from the SQ due to hardware limitations, but adding the 3rd possible instance of MixPad along with the ‘follow sel’, ‘follow mix’ and the most recently ‘use SQ layers’ options are all intended for use of MixPad as a second screen.
As @highflyer190653 points out, you do not need WiFi for this, but can use a laptop or even a tablet with a network dongle connected, and the SQ can self assign a local IP address for a direct network connection.
Ok thank you for your answers
