Security Features
For info, I had contacted A&H presales to ask about the user security features on the GLD-80 and here is the response:
It is possible to set up to 8 password-protected User Profiles, and set different permissions for each one. This is a preliminary list of features or settings that you can deny access to:
SETUP
  • Utility screen
  • Configuration (bus architecture etc)
  • Control Setup (strip layout)
  • Rotary functions
  • Sel buttons
  • Mix buttons
  • Audio Settings (e.g. sync from I/O module)
MEMORIES
  • Show Manager
  • Library Manager
ROUTING
  • Input Patchbay
  • Output & FX Patchbay
CHANNEL
  • Name/colour
  • Preamp
  • PEQ
  • GEQ (outputs only)
  • Dynamics
  • Delay
  • Gang
  • DCA assignment
Unfortunately it’s not possible to apply a permission to a range of channels only.
The preliminary User Guide will be updated shortly to include this information following the release of the V1.0 software.
As with iLive, you can assign a default Scene to each user (not a Show). The user scene gets recalled every time there is a user change.
So if you log in as user ‘Operator’, and you were previously logged in as ‘Admin’, the ‘Operator’ default scene is recalled.
Hi gkhewit,
You can restrict a user to a range of channels simply by assigning just the allowed channels to the surface and then locking out Control Setup (strip assign).
Regards,
Carey
Yes good point, applies as a result of the last paragraph I guess (using default scenes)
