I second this one, I’m quite regularly using MIDI controllers to control the SQ, mostly with some intelligent tool like Bome MIDI Translator in between, and having the option to know which channel is currently selected and be able to select one would be very useful.
Just to note, sending a message on channel selection might be possible, and similar in some way to the ‘follow unit channel select’ feature in SQ-MixPad.
Selecting a channel based on an incoming MIDI message may not be possible however, due to the many corner cases and potential problems. e.g. what if that channel is not assigned to a channel strip?
Thanks, Keith.
