Selecting channels above channel 16 on ME-1
We are using the QU-PAC and the AR2412 dsnake. I’m trying to select channels above channel 16 on my ME-1. It doesn’t seem to bring up the channels and names that are above channel 16 even though it’s set up on the QU-PAC. IE - channel 17 is named VOX1 and is configured and set up on the QU-PAC. But the ME-1 is not showing it. What am i doing wrong?
Hi Mario,
Check the outputs in the Monitor tab (Setup / I/O Patch). You can patch any combination of inputs and mixes to the ME-1, perhaps channel 17 and higher are unassigned?
Does the ME-1 key setup / source assignment list all sources with their names?
Thank you Nicola! I’ll try that.
It worked, Nicola. Didn’t have my I/O Patch set up right.Thank you!
Mario
