Send Main LR to Aux out
Is there there a way to send the main left and right to an aux for a mono out.
The easiest way to achieve this is to set all your sends to that aux to 0dB unity gain and set the aux to be post-fader - it has the same effect. On CQ, you can’t reroute the outputs.
Good morning, I too would be interested in having other main outputs to add a delay line, or to control the subs, etc.
On the SQ mixer just create a MainMix
You can, of course, use all 6 Outs of the CQ as described for such things.
However, A&H has stated here several times that additional mixes and Outs are unfortunately not possible.
Issue is it won’t turn down the aux, (subwoofer in this case) when adjusting the master LR fader.
If this is a problem for you, check out the app “Mixing Station”.
If you decide to use it for control, you could there also “link” the faders of your Sub Out and Main LR, among other things.
Therefore you can just add a DCA that controls all outputs you want (e.g. Out1, L/R, …) and use the custom layout to place the fader as you want.
