I have a Matrix for streaming. MainLR is sent to it. I have 5 audience mics to a mic group. I so i also send thehat group to the Matrix, so it can go out to the stream and not to FOH, while still being able to control the mix volume?
Well the phone really mangled that. The 5 mics are to a mix group. I need to know how to send that group to the matrix.
Hi AsherN,
Select the Group
Goto Routing (Green Switch)
Move the screen all to the right (Mtx are the last sends)
Greetings dd
And don’t forget to turn the audience mic group ‘MainLR’ (FOH) off in the Routing screen also.
A side note: If you have only one input channel with a audience/room muc, you can use “ext mix in” to add it to a “dry” mix.
Also may want to “mix” the audience mics into the live steam as needed.
Leaving them up in the live stream mix during the spoken word presentation parts
of the service it will sound like a big open room to the live stream audience.
