Send output over network
Is it possible to use the network output on the SQ-5 to record to a PC? I know you can record from USB-B, but I can’t seem to find anything stating yea/nay about recording over TCP/IP.
We do plan to be using iPads to control the unit, not sure if that is relevant or not.
No. The network port does not send or receive audio. It is for control data only, which means you’ll need it for iPad control anyway.
You could fit a Dante card and record from that if you need more than the USB-B port offers.
If by network port you mean the one in Dante or Waves card, then yes you can record from it. Not from built-in network port that is used for control data only.
