Sending Backing track to AR84 output for stage loudspeaker amp?
Hi, struggling here. Just an occasional user of A&H QU24.
How do I route a channel with CD on it to an output on the AR84 to feed a backing track to an amp & loudspeaker on stage?
Any advice appreciated. Thanks
Just like setting up a monitor mix.
Select the mix you want to use, you can make it pre or post fade, with the mix selceted
the faders are in sends on fade mode, bring up the fader for the channel or channels the
CD player is connected to.
For the AR 84 output routing go to the set up IO menu, under the stage box tab select outputs, assign one of the four outputs to be the mix you want to use for the monitor.
Hi Mike C,
Great, thank you. I’ll have access to the desk later so give it a try.
Many thanks
Dave
