Hi folks,
We have a show coming up where we are having to use our QU-16 as a monitor mixer and sending several feeds to the FOH. The LR main output is only sending drums. Mix 4 is sending only lead vox. Lead vox needs to have reverb. I don’t see a way to have reverb on the lead vox unless it is also going through the Main LR. Is there a way to do that? Thank you!
There are several options.
You can use the fx as an insert.
Or you can set the fx as pre-fader, mixing the vox channel and fx return to mix4.
Or you can un-assign the vox channel from LR, so the fact that the fader is raised won’t mean anything.
Or you can send your drums out a different mix.
How are you putting the reverb on - if you use mix->return then you can assign the return to as few mixes as you like …
Thanks guys. Unassigning the VOX to the LR worked great. Thanks again!
