Sends on encoder and faders
I have an ilive T on its way and was wondering, when you place the sends on the encoder if the channel fader strip is still active to adjust the channel volume in the main mix. For instance if I had a channel I was riding gain on but, needed to make a quick adjustment to an aux or effects send. Could I potentially do both at the same time (considering I had enough dexterity to do so and could make my brain multitask like that :tongue: )
update: It seems according to the manual that you can but, I wanted to make sure.
Hi Kent
Yes if you set your Aux’s to send on rotary’s then you will be able to have control of the input channel level on the fader and send level on the rotary.
Also available on Rotary are Pre amp - Gain/ Trim Control, Pan, Sub Send, Direct Output level.
Hope this helps
Sam A&H
Is there any chance that we can have the FX sends as options in the drop-down lists, because we don’t use pan/sub/gain/directs a lot, but FX sends most of the time?
Thanks.
