I did first recording (multitrack - to sd card) with CQ20b on Friday.
I was a little bit worried to not to distord recorded wav-files.
Tried to check info from user manual, but failed to find any.
Just to be on safe side, I kept levels below 0dB. This meant that some close mics had to be adjusted to have Gain setting as low as something like 1 or 2.
Recorded wav files ended up being very quiet, so I had to boost them something like 20dB in DAW.
I suppose I should aim for something else than just “under 0dB”? In gain page, there is PK mark nearby level meter. It does not say any specific number, but I believe it is between +12 and +16dB. Is that actually maximum level for SD card recording?
