Share connection from iMac?
Hi. I am trying to configure my Qu-Pac and iPad. It works when I connect the Qu-Pac to the router with ethernet cable.
But it is on the other side of the house.
I should be able to share the wifi connection from my Mac right beside it, right? Just connecting a ethernet cabler from the imac to the Qu-pac?
I am triyng but cannot gety it right.
What settings in the network settings of the mixer do i need?
What settings on the mac?
Thanks for help.
You need to have a dedicated router for your connection between the Qu-Pac and the iPad. You can’t share wifi connection through another computer to your Qu-Pac. The dedicated router should be hooked up to the Qu-Pac via one of the router’s output port, NOT the Internet port. Then your iPad needs to connect, via WiFi, to the network that the dedicated router is broadcasting, NOT an existing network connected to the internet.
Ok. Now i see. I placed a airport express right beside it and that did it. Thank you for the help
You can plug it into an existing network - I do so at home for testing.
I would not suggest it for studio or live work though.
