Hi!
If anyone has a recorded multitrack from a band that is possible to share I would be very grateful. I just bought my SQ5 and would like to experiment a bit before using it live. A short loop with a few instruments would be fine…
Lars
This site has a bunch of multitrack files that are available to be downloaded, and covers pretty much every genre of music. The 'Mixing Secrets' Free Multitrack Download Library
Most are in 44.1, so they would need to be played via a DAW in SQ.
**To clarify, you would need to CONVERT the sampling rates of these files. I tried loading the converted files onto SQ drive in the past, and it doesn’t work, while using a DAW it does.
Hi all,
We have a guide on re-rendering files for SQ-Drive playback here - https://support.allen-heath.com/hc/en-gb/articles/4402940122001-SQ-Re-Rendering-Files-for-SQ-Drive-Multitrack-Playback
This should enable you to take any of the many (free for personal use) multi-tracks available online and start having some fun with your SQ ![]()
Thanks for this Keith. I’ll give this a try sometime.
