I have a Qu-24 and will be doing a job at a facility that already has their own Qu-16.
If I create a scene ahead of time on my Qu-24, can I load it into their Qu-16 provided both have the most recent firmware?
TIA
TIA
AFAIK yes, but obviously the features in the 24’s scene that don’t apply to the Qu16 (eg mtxs, groups, ch17-24, extra FX buses, last 8x faders on the custom layer, extra softkeys etc) won’t be recalled on the Qu16. If you then save the scene on the 16 and put it back on the 24, I think you lose those all those extra things too. You’d also have to watch your patching with Qu-Drive, USB-B and dSnake if any of those aren’t on defaults when you recall your scene (eg if Qu-Drive track5 was set record input24 on the QU24, then you loaded up the scene on the Qu16, Qu16 doesn’t have an input24. Not sure if it would record the default for track5 (input5) or if it would record nothing. Best to check anyway.
got it,
I think you’re right,
thanks Cornelius!
Dan
Hi Dan, Cornelius is right. Shows are compatible but any sends to busses (FX, GRPS, MTX) and assignments would not be recalled. Assignments any channels which have been unassigned from LR in Qu-24/32, would need to be reassigned in Qu-16.
Cheers. Harry.
sooper dooper!!!
Thank you Sir!
