Using the editor software create a sample show using the T112/iDr48 combination. Switch the editor to T80/iDr64 and read in the show file. It should show you exactly what the hardware would do.
iDr48/T-112/MADI/Dante
How do you do that without closing and re-starting editor?
You have to close Editor and re open with the new surface config. Then reload your saved show to see the changes. The main changes will be your channel strip layouts on the different surface.
Cheers
Richard Howey
Audio Dynamite Ltd
