Same as scenemanager but for shows;) this seems to be relevant for all venues with different technicians using mixpad, cause If a scene happens in one show, you will never have access to it in another show again.
I want to load shows with filters for every kind of scene- and showdata mentioned on page 50 in reference guide 1.4.0
Scenario:
Band technician also uses sq6, got everything prepared. Although we’ve got all data needed, there’s simply no possibility that one of our shows has to be changed by hand, if we want to run one show during the whole evening. wasting time…
The showmanager should include the function to copy a single scene from one show to another show using the filters mentioned above.
Scenario:
Small club, different people at the mixer but same equipment every evening. Everyone is using Mixpad app for preparing their events. So every persons show includes the scenes they pulled off the mixer and those they prepared and then used at the event. The problem occures if someone has to mix a band, a different technician mixed before. Or even worse: one band from your own show and one band from another’s show and you have to play the music in the break…
There’s no way to have quick access to all relevant scenes of one venue for different users. If a scene happens in one show, you will never have access to it in another show again.
Even if you have both shows for both bands on one device/USB stick, you load the second show not knowing which routing changes etc. may also occures without research. So you’ll do it again by hand, wasting time again…
Right now to have everyone’s scenes up to date, the show would have to be pulled from the board every evening and uploaded to cloud, which would minimize the time for preparing on Mixpad to maximum one day for the next staff.
A great board we all love to use, but it’s not “social” one;)
