Side Chain - how to?
Hi everyone,
Please accept my apologies in advance if I’m being stooopid … :smiley:
I want to use a different signal to control compression through a side chain, but I can’t find the setting to select this signal, if indeed this is possible …
I want to use vocal signals to trigger compression of the keyboards in our mix, to allow the voices to come through clearer without having someone ride the faders! :smiley:
Any help would be most appreciated.
www.pianodome.nl
3D PianoShow!
I would add that I’ve trawled through the search results and watched what I believe to be the appropriate A&H videos on the YouTube channel.
www.pianodome.nl
3D PianoShow!
You can select another signal as long as it is in the same ‘group of 8 inputs’ (hardware based restriction)
Screenshot of editor:
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
Ah! You are a magnificent person, Wouter! :smiley: Thanks!
www.pianodome.nl
3D PianoShow!
The new Multiband compression is GREAT!
However: it’s a shame that you can’t trigger compression in one band through side chain. Using side chain, you can only trigger the per-channel compression … or am I wrong?
www.pianodome.nl
3D PianoShow!
