SLink Option Card
Hi all,
You may have spotted it on our social media already… but we have just released the brand new SLink Option Card for SQ :slight_smile:
It works in exactly the same way as the built-in SLink port, and has independent SRC, so now you can connect two different protocols to the same SQ!
All the info is available on our website now : (https://www.allen-heath.com/ahproducts/sq-slink/).
Cheers!
Hi Keith
Good to see this finally released. Is there a price available?
Can’t seem to find it on your main UK distributors websites?
Hi Vermaak,
MSRP: $189.00 :wink:
Nailed it then!
I was hoping that it would be a reasonable cost compared to say the Dante card (which I guess has licensing costs associated).
Big question is when the UK suppliers will get it in stock?
firmware v1.3 is needed?
Can i connect the me-1 thru a poe switch directly to a slink bus?
Richard
Hi Richard,
…more announcements to come in the next few weeks :slight_smile:
We only support either direct connection to the SLink port (when using no expanders of course) as although in theory it is possible, you would need to use a switch and/or a VLAN.
I mean that if it is possilble to connect a poe switch to the slink card and the me-1 to the poe switch.
The same as to the monitor port of the ar2412.
Richard
Hello - with the SLink Option Card, I see it says that you get an additional 128x128 and that it runs independently.
Does this mean that if I used the card with an existing Dlive system (DM64 and DX32 expander) that I could use all 96 inputs on the SQ7 for monitor purposes, or would I be limited to 48?
Thanks.
You can route any of those 96 dLive inputs to the SQ. In fact you can even route outputs and mixes of the dLive system to the SQ. But you can’t use more than 48 inputs at once with the SQ.
What still confuses me: Why can a QU be connected to the SLink-Card, but not a GLD? Don’t they both utilize DSnake? It pains me, that the only way of interaction between GLD and SQ is Dante with >1000€ investment for two cards…
Hi Lino,
Neither Qu or GLD were ever intended to be able to be connected to another desk directly.
The ability to connect an SQ to a Qu came about because we were able to change the behavior of the Qu and make it discoverable to an SQ over dSnake. This is not possible with GLD.
So whilst both desks utilise dSnake, it is not the protocol or SLink that is the restriction - it’s the way the GLD platform works.
Hi Keith,
I read this card can be used to do a FOH/MON split. I have the SQ6 as FOH and am adding a SQ5 as a broadcast split with 2 AB168 stage boxes. Could I use an ME-U to perform the split or is there an easier way?
Hi Keith,
The ME-U is used to distribute audio and provide PoE power for ME-1 and ME-500 units.
For the setup you describe, the addition of an SLink card in the SQ-6 would allow you to connect to both the AB168’s on stage, AND the SQ-5 at the same time.
No other equipment needed :slight_smile:
Cheers Keith!
when will it actually available from uk distribution…
Follow-up to Keith’s question - can I set up a SQ6 at FOH, an SQ5 at broadcast, 2 DX168s on stage and ME-U on stage as well, using the new SLink card?
Hi Twonder,
As DX boxes use a different protocol, the set up described above wouldn’t be the same situation as the one you described.
That isn’t to say this set up isn’t possible.
You would need an SLink card in both consoles, with one port in each used to link the desks, and the other to do DX or ME.
Alex
SO Can I control a Dlive Mix-rack DM64 through the Slink Option card with an SQ6
No. The dLive controls it’s preamps. The SQ6 controls it’s preamps. You can tap into them. But you can’t control them.
