SLink over IP switch?
Hi. I’m excited cause I just ordered the Avantis and should be receiving it soon.
I’m sure the answer is “no” but just wanted to check. Is it possible to use SLink over a normal off-the-shelf IP switch? I have two rooms that don’t patch together. I was wanting to run 2 D-Link Ethernet powerline adapters to run the SLink from one room to the other. I’m almost certain it’d work over Dante however I prefer SLink cause I’m using a GX4816 that already has a ME port on it. Any advice or info would be much appreciated. Thanks!
This is kind of complicated.
As I understood it (but not verified) is the new Slink Port a auto adapting port, wich switches between different Protocolls.
The Old Protokol wich was used by GLD & QU are not TCP/IP Based. They are not possible to route over an switch, because of the missiong layers (layer 3 or 4) wich are necesarry for the routing within the Switch.
I think the newer protocolls of SQ and Avantis behaving the same, cause they are mainly made for simple point to point connections.
BUT:
The Avantis also supports the newer Protocolls of all the D-Live Stageboxes, the DX Boxes. And as I understood it, here is a Protocol used, wich ist based on TCP/IP. And the GX4816 is also capable to be used by this protocol.
But I’m not shure, how it would behave. There is a small chance, that it works. Please stand me corrected if not.
Savest Way is a direct connection, without the router. If you have a propper Houseinstallation, you should be able to just make a direkt connection on the patchfields.
The other possibility is Dante, and using a Dante Box or other Dante Hardware. Dante is a TCP/IP Protocol and qorks quit well.
Kind regards
the use of a switch is possible
as long as you have no other devices in the same network
the SLink is a point to point connection based on standard Ethernet
but I guess the powerline will be a problem
this will introduce latency that will cause problems and makes the link unreliable
