Slow startup R72
Hello,
My R72 is starting up very slow… Is it normal or can I replace the HDD with an SSD or is there another solution?
How do we know if its NORMAL if you don’t tell us how long it takes to boot???
Here’s a solution- start it earlier than you need, go get a Coffee. Lol
Solution 2: check your network settings: If DHCP is enabled and there is not a DHCP server connected to the system - for example a router with DHCP enabled - boot time will be increased greatly. If this is the case either connect a DHCP server to the system or choose static IP addresses.
Hi Wouter
my R72 takes about 2 minutes to boot.
The IDR32, R72 and the WLAN router are configured with static IP addresses, other equipment like PCs, MACs and iStuff get dynamic DHCP addresses.
Hth
Juerg
