Snake telemetry - offline warning mechanism
Could a snake ‘offline’ warning option be made available please.
For safety reasons at a recent gig I was obliged to use RCD circuit breakers on every mains outlet (13A mains plugs in walls) in this old building.
Sadly, and you guessed it, one tripped that was powering a AB168 snake box.
Given the pressure at the time it took a while to work out what was going on… had a mic failed (it was using phantom) … had a cable failed … etc etc.
A simple ‘Snake box two’ or ‘snake box one’ has gone offline message on the LCD screen would have been a great tool to quickly identify the fault in the event of a power fail.
Yes I had an AR08 go down once and that was behind a screen off to the side of stage, I couldnt get to it the see it.
All of the vocal went down and like a I repowered the mixer. But all I had to do was unplug\replug the AR08 and it would have picked up sync within seconds,\ however I didnt know where to start looking.
Right smack in the middle of a show.
So maybe thats a good idea?
Although it’s not a notification, a quick way to get an overview would be to look at the input source screen. If you see “N/C” where you expect to see “Main” or “Exp” then you have a problem. Alternatively there are the IO patching screens buried in the setup menus. Maybe there could be a different dS icon in the taskbar to denote that an expander is connected?
An “E” would be good, I presume the presence of an expanded assumes the main stagebox is working
The quickest way to tell when the expander goes off line is by looking at the source. Of course if your on a QU32 and you have your vocals over on the last channels… youre history
It can lead to a very fast meltdown.
To me I would like a full screen flash Dsnake OFF LINE
Something quite substantial!
