In 1.5 I had a soft key that controlled Arm/Rec/Stop (Red flashing/Blue). I upgraded to 1.6. The guide for 1.6 says it should operate the same but now it just goes from Blue = stop and Red = Record. Is this wrong - is something wrong?
Unfortunately, A&H simply removed the arm function in 1.6 and forgot to do the same also in the guide.
OH, so it is now simply start rec/stop rec. does it automatically create a new sound clip on my USB drive each time I start and stop?
Yes, but look on the bright side: You’ll save yourself a keystroke every time. )
Your right - must simpler. Thanks
With pleasure.
However, it was only meant ironically. )
