I might have misunderstood the command “scene recall go”, but I need to be able to go to the next scene and recall it - by the press of a soft button.
Doesn’t make a difference if I chose “Auto increment” or “none”.
Or is there another way of doing this with just one push of a button?
Best regards
Anders
Hi Anders,
Setting a soft key to ‘Scene Recall Go’ with ‘Auto Increment’ switched on will recall the next scene and advance to/highlight the next one, ready for you to recall again.
If it’s just a single specific scene you want to recall, you could make use of the ‘Recall Scene’ Soft Key Function and set it to the scene you wish to recall.
Something to be aware of is that Soft Key assignments are stored in scene memory, not show memory - so you’ll need to set that Soft Key assignment on all the scenes you want to work with.
Hope this helps!
