soft keys and midi
In a future update would it be possible to be able to set an optional midi command string to be run when the softkey is unselected.
thx.
Carl.
Use-case: swap pre-amps that match a DCA to/from input sockets/ dante io- ports. i.e. select softkey, swap pre-amps to dante, unselect swap them back.
I can do this scenes, however if the midi protocol is also expanded so that the input on the pre-amp can be selected from midi (add input selection type and number) and not using scenes, that would rock!
Carl.
