Soft Keys may call Mix Busses on screen
I’m the drummer and sound man in my band. The mixboard is next to me, I make the sound for me and my three mates.
I come from QU16.
I bought a CQ18 recently because of its weight.
Everything is OK except one thing :
On QU16, I push a simple key, the console flips to a Mix Bus immediatly.
On CQ18, I have to press “Faders”, then I have to look for"Sends to" somewhere on the screen, press it, then select the right Mix Bus on the screen : Three operations, and I need to look carefully for every one of them.
My request :
I press “Soft Key 1”, the CQ18 flips to Mix Bus 1.
Simple and fast.
I know this doesn’t help you at all, so my apologies, but this is one of the things I like about my workflow of using a CQ20B, mixingstation and behringer x touch. On one hand, it’s more parts to the equation than simply using a cq18, but on the otherhand, I’ve been able to map the controller exactly how I want it and I get motorized faders and scribble strips.
Back to the notion of the soft keys, it would be nice if you could map those three buttons to specific mixer views. I imagine it wouldn’t be too terribly difficult for allen and heath to implement such a function. Definitely worth them considering, provide they ever update their firmware, outside of the occasional bug fix.
… or someone takes it upon themselves to attempt vibe-coding custom firmware. Not endorsing the use of generative AI, but I am seeing some interesting projects pop up on reddit - custom arturia microfreak firmware, for example. Again, I must insist that I have not personally loaded my microfreak with custom vibe coded firmware. I just don’t have my head in the sand pretending those intriguing yet controversial projects don’t exist.
Thanks for your answer.
Funny : I used also Mixing Station and a Behringer XTouch when I was on Behringer XR18. It worked but it was a complex setup.
Then I moved to QU16 : All in one, intuitive, easy to use. But bigger and heavier.
So I moved to CQ18 for small venues : Small, plug and play, WIFI router included…
I miss one thing : Call a bus on one button.
Like EVERY A&H console does by the way :grinning_face:
