Soft Keys not properly following control state (stays linked to track 1)
I found another problem, now with the Soft Keys.
In the Android app, they don’t seem to be consistently following control state, which leads to a lot of confusion.
I noticed this so far for Mute and Pan Center control, but it likely is a more general problem.
Note that I did select Current Selection as the source, so it should follow when I select any other track (but it doesn’t).
One example: I select the first track, mute it using the soft key, mute goes on and soft key also goes to red (which is great as a visual confirmation), but when I then select track 2 and apply mute, that works, but the soft key’s visual state stays linked to the first track. Same for Pan Center soft key function (green color in this case).
Can this be fixed?
