Soft Rotarys?
looking to see if I can assign FX decay time to a soft rotary… or FX delay time as well…
also… talkback level and on/off to soft rotary 4 for example
is this a show stopper? Don’t think so…
nope but would be good for folk like me :slight_smile:
But why is this post in the troubleshooting forum?
I would second that it would be very useful to be able to control talkback channel preamp gain with the soft rotaries - this is possible for all of the other local inputs so appears to be a simple update to add this ability.
It’s not.
It’s in the RFE forum, where it belongs. :slight_smile:
One more for “Changing Decay” or “Changing Delay Ratio”.
And I wanna see the values while turning the knob.
+1 for both suggestions, it’s nearly usable at the moment.
+1 for FX Parameters on Soft Knobs
AND: We need to see the Values while turning the knob :slight_smile:
+1 for FX delay and decay times on SoftRotaries
With V1.3 you can use the Softrotaries to control a time parameter and on some fx types also a second parameter. The value is displayed while you change it or when you use the view button. See new manual on page 57 which parameters for the different fx types can be assigned to the soft rotaries.
Now the soft rotaries become more and mor useful. A custom label and color would make it even more useful.
Where can this new manual be found ?
https://www.allen-heath.com/media/SQ_ReferenceGuide_V1_3_0.pdf :slight_smile:
Thank you
really, full customized SoftRotaries assignment is very needed as for me.
otherwise i can’t find any proper usage choices of SoftRotaries
