Softkey muting a send
Hi
Does anyone have a solution to using a softkey to unmute then mute a send from a channel. Ive looked but cant figure out a way to do it I need to quickly turn on a aux send from a vocal channel then mute it. Using the routing screen and selecting channel is not quick enough for what I need to do as I have to be on FX screen at the same time anyone know a way round it.
Dave
If there’s no direct way of doing that (don’t have console around now) you can Y-split the vocal and mute channel going to Aux by button.
ddff
I only want to mute one aux send from the channel not other aux sends or the whole channel.
Hi Dave,
Not exactly the solution you were hoping for but if that Mix is active on the Master strip, you can hold down assign and press the Sel key of the channel to toggle on / off on that Mix. No need to access the Routing screen this way.
Hope this helps.
Dave- you can still have the first of Y channel going to other auxes, just the second channel routed just to THAT aux would be muted.
ddff
Hey Dave
What I do is assign the aux(s) to a DCA, freeze the DCA fader at unity, assign the DCA to a softkey, then remove the DCA from the surface strip to save real estate.
Len
