Softkey Scene Toggle On/OFF
Would be great to be able to hit a soft key to recall a filtered Strip assign scene, and return to another (default) filtered strip assign scene once the soft key is turned off.
How it works now, you need to use up two soft key slots for each scene, this feature would add the ability to set the scene for the on and off state independently.
You can kinda do that now… you can reprogram the softkey in the 2nd scene to recall the 1st scene, but that assumes there’s one single scene you’d want to go back to. Plus, the softkey illumination gets weird because it’ll come on when you go back to the first scene, but then it’ll turn off when you recall any other scene.
Also, it’s just one more thing you have to keep track of in the scene filtering.
