Two Feature Requests that ‘should’ be easy??
Let the Custom Rotary Knobs control the Fader Level of a DCA. It can control a channel already, but not a DCA (there is no DCA option for ‘Level’). My reason for this request. I run a LR Output with Fader, An Aux Sub Output with Fader (Matrix/Aux or M) and another for Front Fills. I use a DCA on all of these so when I adjust this, it adjusts ALL my outputs with one Fader. If I turn down the DCA, it turns down everything instead of having to do turn down each individually. Instead of having to keep the DCA on my Fader Bank, it would be nice to have one of the custom rotary knobs be able to control the DCA. Then I would have control of that on any layer without having to take up the space of having a DCA Fader there.
Would be great to be able to program soft keys to just ‘show’ Effects on the Touch Screen. I don’t usually have all of my effects on my main layer, so to make adjustments (pre-delay, feedback, etc…), I have to go to that layer and click on the effect to bring it up on the screen. With 12 available FX, that can become time consuming and bothersome to say the least. If I could just program softkeys to specific FX, then all I would have to do is press the softkey to show the effect that I wanted to modify, no matter where I am on the layers. It could be a ‘Go To’ option in the Softkey dropdown and in reality, you could be able to pick any item to ‘go to’ and not even limit it to FX.
