Solo Button automatic volume boost when selected?
Does the solo button on CQ18 automatically add a bit of a volume boost? It’s appearing that it does, unless I’m missing something. Not a problem, just want to know.
According to the bloc diagram, the PFL (pre-fader Listen) is taken before the fader for any channel.
So yes there is a difference of level depending how is set you fader.
Thanks for the reply.
So if the channel fader and master fader are at nominal, and all processing is bypassed there shouldn’t be a difference, is that right? I did all that and still hearing a boost.
I’ll give a try also and come back here.
So after checking I confirm that I have no boost with PFL engaged if fader is set to 0dB.
