Solo in place
Hi
Please make an solo in place option.
Soooooonnnnnnn!!!
yesss
Output from monitor bus instead of L&R then use PFL?
Just have the option with or without Solo in place in the menu , then when you are in linechek , you can isolate the selected Chanel in your headphone or master except the fx return still in isolate
Hope soon …
Just like on all the other desk in the world ??? you are so good … I can’t believe that you don’t have this and the simple midi pgm change in the scene menu …
Please
Is solo in place still not available?
Any news on the possibility of SIP appearing in a future update? It’s such a basic function, crucial to an effective virtual soundcheck.
As a workaround you can patch the IEM output to the PA for the virtual soundcheck.
On that way I use the dLive as a studio desk.
Interesting point, loloverde.
I have to look into that if the IEM can be routed to the L/R bus, or a physical output only…
No, physical outputs only.
So this is of no help for me, as my PA system is driven by several Matrixes fed by the L/R bus.
Or I don’t find the necessary function you are talking about?
I use matrixes for L,C,R, front fills, sub bases, out fills, etc.
I don’t think routing PAFL bus to this many matrixes would be practical, also it would bypass my LR Master where I use additional processing before sending the signal to those Matrixes.
@mixJM: you can not route the pafl to the Matrixes, but the corresponding output patches only. At least if I am not missing something.
But I get your point, as it has the same result what I mentioned above. Using the output patch will leave all the processing in the Matrix masters behind.
+1 for Solo in place function
