I´m now working with dLive C2500/CDM32 and DX32 regularly since 3 months and here are some points I have on my wishlist:
IP6 / IP8: I miss the “Mix” and “Select” Button. Then it would be nice to have a “FOH-Mode”, “Individual-Mode” and "Director-Mode.
In “FOH-Mode” the IP8 reacts like a Surface-Extension. When you press the Mix Button, all Faders and Channels from the Surface and the IP8 will react. So if you have FX-Send on the IP8, you can press the Mix-Button on IP8 and make the settings on the Surface (like an additional bank on the surface).
In “Individual-Mode” the Mix-Button would react only to the channels, which are defined on the IP8/IP6
In “Director-Mode” it is like “FOH-Mode” but interacts with Director Software instead of Surface. This would be great for small Jobs, where no Surface is needed. -
Assignable Rotaries: Here I wish more flexibilities. One thing I would wish to do is, first rotary = Rev Time FX1, second rotary = Rev Time FX2, third rotary = Delay Feedback FX3, fourth rotary = Chorus Intensity and so on
Soft Keys: it would be great, if I could turn on or off an individual EQ. For example: I often use a “Telephone EQ” on the Delay Return Channel. Now I want to turn it on or off with a soft key.
Phantom Power: I want to choose, if I have to press long for 48V or only short. It would even be nice, to have the 48V switch as a soft key, corresponding to the actually selcted channel
Best regards, Christian
