Regarding the GLD-80 is it possible to use the aviom out
on the ar2412 as a split snake for other digital mixers.
If not what would be some recommendation on a cheap easy
split snake for the GLD-80?
Tanner
Tanner
Use Dante.
M-DANTE option card in the back of the GLD means that you can then send/receive 32ch over a Dante network which could consist of multiple devices such as another mixer (e.g. another GLD or anything else that supports Dante) or a DAW for multitrack recording.
Awesome, thanks for your help
Tanner
would the Allen and Heath M-ACE-A work the same
was as the Dante?
It seems to be much cheaper and sounds like it does
the same thing.
Tanner
M-DANTE is 64 channels i/o
And will also allow recording with a laptop and software only, and 3rd party interfaces too.
T112, iDR48 w/M-DANTE, PL10, MixPad, Editor
GLD-80 w/M-DANTE, GLD-AR2412, GLD-AR84 (2)
MacBook Pro, Mac Mini
Lion/Logic Pro/PT10
All latest versions/firmware
Sure, you can also use ACE card, but it’ll give you only point to point connection to another A&H mixing console. Dante is more flexible option.
ddff
