Hello, i’ve try the crossfade setup on my SQ5 between scene and it dosen’t work ?
I didn’t try it yet. Did you try it listening to audio? The 1.6 reference guide states that the faders will move instantly but the audio wil cross fade.
I updated the firmware specifically for this feature…The cross fade does work. Whats does not work is the movement of the faders…The faders will snap to the scene but the audio will crossfade…i suspect there will be a firmware update coming to fix the faders…other than thats the cue list and crossfades are what I have been waiting for.
Ron
dLive cross fade has always been this way as well, so I wouldn’t anticipate that changing on SQ…
Based on a facebook response to this exact discussion…If the faders reflect the cross fade time you are locked into watching the crossfade happen without being able to do anything with the faders until the crossfade completes. This was the audio crossfades and the faders are available to be adjusted/takeover the crossfade if needed.
Ok I try it with sound and it work’s well.
