Hello Friends, do you know if it is possible to connect the “Audiolab Live Snake 16.8” device to an SQ5 console?
I attach the device manual
Thanks a lot
Thanks a lot
Hi @fher ,
It appears the manual was too large to attach here, but having looked up the unit online, it uses a Dante interface for the digital connection.
So yes, presuming the Dante on that unit is either 48kHz or 96kHz (doesn’t appear to be included in any spec info I can find), you would be able to connect it to an SQ via the SQ-Dante option card.
Note that there would be no remote preamp control as you would get with any of the similar A&H expansion options (AB168 or DX168 direct to SLink port, or DT168 also via SQ-Dante card).
Cheers,
Keith… the product has no remote controllable preamps… nothing is remote controllable and I’m not sure about the Dante connection… 8x8 on a 16 input stage box?
Strange product… so far away from the market… so 1995
very bad descriptions…
I will work i think but what qualitie are the pre amps?
I think you lose the super qualitie of the sq spe amps.
The dante card is somewhere 600 euro’s, with a bit money more you buy a dx168.
The dx168 hase dlive pre amps. This is a beter option.
Richard
