SQ-6 Default Boot Layer
Hello All,
Is there any way to specify any layer other than “A” to boot into? I prefer the default input strips as is/where is on Layer A/B/C but have programmed a custom layer onto layer F and would prefer to default boot into that layer on startup rather than re-programming Layer A. I know it’s a minor thing but I have multiple users that only use one or two inputs on my custom layer that don’t fall into the default strip layout on A and reminding them how to change layers has been an inconvenience at times.
Not sure if what you want is possible rn.
BUT
Just shift all of your layers down one and put the simple 2ch layer as “A”. That way a less experienced person could turn on the board and use it without issue.
Cheers!
