Hi guys, just wondering what’s your solution to having different(reverse) panning for stage and FOH. I am currently using a drum group (for example) to me-500 to have it take up 1 of the 16 but depending on how i’ve panned the drums you want the opposite when you’re on stage. So would love to hear what you guys have done!
Which ME- 500 button (e.g., odd or even) is selected doesn’t make a difference for panning on Me-500.
Try this…
You have your FOH panning in LR out, correct?
You then have your drum group, selected as a mix instead of a group, panned opposite, and NOT sent to FOH. (So FOH is mixing from the inputs, not from the group). Select that drum group (mix) as a stereo input to ME-500.
I’m pretty sure this would work, but I’ve been proven wrong so many times…
It is a kinda complicated method on Me-500 that requires a Group turning into a Mix on the Mixer itself.
Me-1 is more straightforward in that you can create a drum group on a single button of the Me-1 itself, then pan to your hearts content, never sacrificing a mixer group.
In some ways, the Me-500 is optimized for bands just wanting the first 16 mono or stereo inputs.
